IPS_SetVariableProfileValues
boolean IPS_SetVariableProfileValues (string $ProfileName, float $MinValue, float $MaxValue, float $StepSize)
ProfileName | Name of the profile. Available profiles can be queried via IPS_GetVariableProfileList. |
MinValue | Minimum value used for the visualization. This soft limitation does not affect the variable value. |
MaxValue | Maximum value used for the visualization. This soft limitation does not affect the variable value. |
StepSize | Step size used for the visualization to create the setpoint change bar. A step size of 0 activates the association list. |
The command sets the minimum value, maximum value, and step size of the variable profile with the name ProfileName to MinValue, MaxValue and StepSize, respectively.
Standard profiles cannot be changed. These profiles names begin with a tilde (~).
IPS_SetVariableProfileValues("Temperature", -10, 40, 0.5);
