IPS_PresentationExists
Require: IP-Symcon >= 8.0
boolean IPS_PresentationExists (string $PresentationID)
PresentationID | The ID of the presentation to be checked, formatted as GUID |
If the presentation exists in the system, TRUE is returned, otherwise FALSE.
The function checks whether the presentation with the ID PresentationID exists.
if (IPS_PresentationExists('{60AE6B26-B3E2-BDB1-A3A1-BE232940664B}' /* Slider */)) {
echo 'Presentation already exists!';
