IPS_GetPresentationForm
Require: Symcon >= 8.0
 string IPS_GetPresentationForm (string $PresentationID, int $VariableType, array $Parameters)
PresentationID
The ID of the presentation, formatted as GUID
VariableType
The type of variable whose form is to be returned
The parameter list to be used for the form. It must not be empty and must contain the parameter PRESENTATION.
The form of the described presentation as a JSON-encoded string.
The function returns the form for the presentation PresentationID, taking into account the VariableType and the Parameters.
IPS_GetPresentationForm('{6B9CAEEC-5958-C223-30F7-BD36569FC57A}' /* Slider */, 1 /* Integer */, ['PRESENTATION' => '{6B9CAEEC-5958-C223-30F7-BD36569FC57A}', 'MIN' => 0, 'MAX' => 100]);
