IPS_GetPresentation
Require: IP-Symcon >= 8.0
 array IPS_GetPresentation (string $PresentationID)
PresentationID
The ID of the presentation, formatted as GUID
The following information is available as key => value pairs:
Index Type Description
caption string The display name of the presentation.
chart array An array with parameters for the display of a chart (see chart table)
condition array A list of conditions that the parameters of the chart must fulfill.
conversions array A list of statements that are used to adjust parameters for different types of variables
form array/string The configuration form determines how the parameters can be adjusted in the variables dialog or the template manager.
format array/string "The formatting of values within this presentation
id string The ID of the presentation, formatted as GUID
locale array The localization of the presentation
presentationParameters array A list describing the default values of the parameters of this presentation
presentationValue string The default value which is displayed in the presentation preview. Alternatively, can also contain PHP code as a string or array that returns the value
restrictions array A list of restrictions that defines for which variables this presentation is available
chart table
Each value can either be a number or the name of the parameter whose value is to be used.
min integer/float/string Parameter for the minimum value
max integer/float/string Parameter for the maximum value
stepSize integer/float/string Parameter for the step size
The function returns an array with information about the variable presentation with the ID PresentationID.
IPS_GetPresentation('{6B9CAEEC-5958-C223-30F7-BD36569FC57A}' /* Slider */);
