IPS_SetVariableCustomProfile
Require: IP-Symcon >= 3.0
 boolean IPS_SetVariableCustomProfile (int $VariableID, string $ProfileName)
VariableID
ID of the variable
ProfileName
Name of the profile. Available profiles can be queried via IPS_GetVariableProfileList. If an empty string is used, the custom profile is disabled.
This function sets the profile ProfileName as custom profile for the variable with the ID VariableID.
The function checks the existence as well of the compatibility of profile type and variable type before setting the custom profile.
Standard profiles can not be changed, if they are starting with a tilde (~).
IPS_SetVariableCustomProfile(12345, "~Switch");
