IPS_SetVariableCustomPresentation
Require: IP-Symcon >= 8.0
 boolean IPS_SetVariableCustomPresentation (int $VariableID, array $Presentation)
VariableID
ID of the variable to which the presentation is to be assigned
Presentation
The configuration of the presentation. Details can be found in the section Presentations.
If the command could be executed successfully, the result is TRUE, otherwise FALSE.
The function assigns the VariablenID variable the Darstellung configured representation.
// Sets the presentation of a variable to Slider
IPS_SetVariableCustomPresentation(12345, ['PRESENTATION' => VARIABLE_PRESENTATION_SLIDER]);
