IPS_SetVariableCustomAction
boolean IPS_SetVariableCustomAction (int $VariableID, int $ScriptID)
| VariableID | ID of the variable |
| ScriptID | ID of the script that should be used as variable action. The nonexistent ScriptID 1 can be given to disable the default action. If a valid ScriptID is specified, it is used instead of the default action |
This function assigns a custom action to the variable with the ID VariableID. The custom action is used in the visualization to forward a change in the variable to the proper function of the module. Examples of action scripts can be found here: Action Scripts
IPS_SetVariableCustomAction(12345, 44431);
