IPS_GetVariablePresentation
Require: IP-Symcon >= 8.1
array IPS_GetVariablePresentation (int $VariablenID)
VariablenID | VariableID of the variable whose representation is to be output |
An array with all parameters of the current variable presentation
The function returns the current presentation of the variable with VariableID. The presentation is available as an array and contains all presentation parameters.
Key | Description |
PRESENTATION | The ID of the presentation used, formatted as a GUID. |
TEMPLATE | The ID formatted as GUID of the template used. |
Display parameters | The display parameters differ depending on the display. The parameters are at the same level as the PRESENTATION parameter |
Possible Presentations
Presentation |
Enumeration |
Date/Time |
Duration |
Color |
Shutter |
Switch |
Slider |
Web content |
Value display |
Value input |
print_r(IPS_GetVariablePresentation(12345));
/* Example
Array
[DIGITS] => 0
[CUSTOM_GRADIENT] => []
[ICON] => temperature-half
[DECIMAL_SEPARATOR] => Client
[GRADIENT_TYPE] => 1
[MAX] => 25
[PRESENTATION] => {6B9CAEEC-5958-C223-30F7-BD36569FC57A}
[INTERVALS] => []
[INTERVALS_ACTIVE] =>
[MIN] => 15
[PERCENTAGE] =>
[PREFIX] =>
[STEP_SIZE] => 1
[SUFFIX] => °C
[THOUSANDS_SEPARATOR] =>
[USAGE_TYPE] => 0
