IPS_GetVariableIDByName
int IPS_GetVariableIDByName (string $VariableName, int $ParentID)
| VariableName | Name of the variable |
| ParentID | Object whose children are searched |
ID of the found variable, otherwise FALSE
This function tries to determine the ID of the variable called VariableName whose parent has the ID ParentID. It will use the ID of the first found variable whose name matches VariableName. If such a variable was found, its ID is returned, otherwise FALSE.
In addition to the name, the parent ID (ParentID) is used as a search criterion. Thus, the probability of finding the intended ID increases significantly. Remember:
Caution: Names in IP-Symcon can be chosen freely, so they are not unique. For this reason, the function can return a wrong ID.
This function generates a warning if the name was not found. Use the @ operator if you want to suppress this message. The exact functionality of this operator can be found in the PHP manual.
$VarID = @IPS_GetVariableIDByName("Rain fall", $ParentID);
if ($VarID === false)
echo "Variable not found!";
else
echo "The Variable ID is: ". $VarID;
