IPS_GetVariable
 array IPS_GetVariable (int $VariableID)
VariableID
ID of the variable
The following information is available as key => value pairs:
Index Type Description
VariableAction integer ID of the instance that is notified about desired changes to the variable. 0 for none or deactivated connection
VariableChanged float Unix timestamp of the most recent variable change
VariableCustomAction integer ID of the script that starts on desired changes to the variable from the visualization. If an existing default action is disabled, the non-existent ScriptID 1 is given. (Since version 2.5 # 2300)
VariableCustomPresentation (since 8.0) array User-defined presentation. Empty array if no presentation is specified.
VariableCustomProfile string Name of the user defined profile. Empty if no profile is specified
VariableID integer ID of the variable
VariableIsLocked boolean Indicates if the variable is above the variable limit and thus cannot be written (Available since Version 2.3)
VariableProfile string Name of the system profile. Empty if no profile is specified
VariablePresentation (since 8.0) array System presentation. Empty array if no presentation is specified.
VariableType (since 4.0) integer Type of the variable (0: Boolean, 1: Integer, 2: Float, 3: String)
VariableUpdated float Unix timestamp of the most recent variable update
VariableValue (until 3.4) array see table Variable Value (replaced by VariableType and GetValue)
Table: Variable value
ValueType integer Type of the variable (0: Boolean, 1: Integer, 2: Float, 3: String)
ValueBoolean boolean Value of the variable depending on ValueType
ValueInteger integer Value of the variable depending on ValueType
ValueFloat float Value of the variable depending on ValueType
ValueString string   Value of the variable depending on ValueType
This function returns an array that contains information about the variable with the ID VariableID.
The value of a variable is get with the function GetValue since version 4.0
The functionality until version 3.4 is provided by the function "array IPS_GetVariableCompatibility(integer $VariableID)" since version 4.0.
// Since version 4.0
print_r(IPS_GetVariable(40770));
/* Examplary output:
Array
    [VariableChanged] => 1246039629
    [VariableCustomAction] => 0
    [VariableCustomProfile] => BoolProfile
    [VariableID] => 40770
    [VariableIsLocked] =>
    [VariableProfile] => ~Switch
    [VariableType] => 0
    [VariableUpdated] => 1246039629
print_r(IPS_GetVariableCompatibility(40770));
Array
    [VariableValue] => Array
        [ValueArray] => Array
        [ValueBoolean] => 1
        [ValueFloat] => 0
        [ValueIndex] => Array
            [IndexInt] => 0
            [IndexStr] =>
            [IndexType] => 0
        [ValueInteger] => 0
        [ValueString] =>
        [ValueType] => 0
// Until version 3.4
/* Exemplary output:
Array
        [ValueBoolean] => 1
        [ValueFloat] => 0
            [IndexInt] => 0
            [IndexStr] =>
            [IndexType] => 0
        [ValueInteger] => 0
        [ValueString] =>
        [ValueType] => 0
