IPS_GetScriptIDByFile
int IPS_GetScriptIDByFile (string $FilePath)
| FilePath | Relative path to the file from the script folder |
ID of the found script, otherwise FALSE
This function tries to determine the ID of the script whose script file matches FilePath. If a script with that file exists, its ID is returned, otherwise FALSE.
This function generates a warning if the name was not found. Use the @ operator, if you want to suppress this message. The exact function of this operator is described in the PHP manual.
$ScriptID = @IPS_GetScriptIDByFile("12345.ips.php");
if ($ScriptID === false)
echo "Script file not found!";
else
echo "The ID of the script is: ". $ScriptID;
