IPS_GetObjectIDByIdent
Require: Symcon >= 2.5
int IPS_GetObjectIDByIdent (string $ObjectIdent, int $ParentID)
| ObjectIdent | Object ident to search for |
| ParentID | ID of the object whose direct children are searched |
ID of the found object, otherwise FALSE
This function tries to detect the object with the ident ObjectIdent whose parent object has the ID ParentID. If such an object is found, its ID is returned. Otherwise, this function returns FALSE.
The parameter ObjectIdent must not be an empty string ("").
__Difference to IPS_GetObjectIDByName:__ As idents of objects are unique within an individual level, either a single ID is returned or a warning is generated.
This function generates a warning if the ident is not found. The @ operator can be used to suppress this message. Please see the PHP manual for the exact functionality of this operator.
// This function can be used to replace IPS_StatusVariableExists
// Example for IPS_StatusVariableExists($id, "StatusVariable");
echo !(@IPS_GetObjectIDByIdent("StatusVariable", $id) === false);
// In addition, the function can be used to replace IPS_GetStatusVariableID
// Example for IPS_GetStatusVariableID($id, "StatusVariable");
echo IPS_GetObjectIDByIdent("StatusVariable", $id);
$id = IPS_GetObjectIDByIdent($VariableIdent, $InstanceID);
$v = IPS_GetVariable($id);
// Array since 4.0
$sv = Array(
"VariableID" => $id,
"VariableIdent" => $VariableIdent,
"VariableName" => "N/A",
"VariablePosition" => 0,
"VariableProfile" => $v['VariableProfile'],
"VariableType" => $v['VariableType'],
"VariableHasAction" => ($v['VariableAction'] > 0),
"VariableUseAction" => ($v['VariableAction'] > 0)
// Array until 3.4
$sv = Array(
"VariableType" => $v['VariableValue']['ValueType'],
