Management of Objects
IPS_GetChildrenIDs | returns a list of all children objects |
IPS_GetLocation | returns the complete path to an object |
IPS_GetName | returns the name of the object |
IPS_GetObject | returns extensive information about an object |
IPS_GetObjectIDByIdent | returns the ID of an object by its ident |
IPS_GetObjectIDByName | returns the ID of an object by its name |
IPS_GetObjectList | returns a list of all existing objects |
IPS_GetParent | returns the ID of the parent of the object |
IPS_HasChildren | checks if an object has child objects |
IPS_IsChild | checks if an object is a child of a parent object |
IPS_ObjectExists | checks if a specific object exists |
IPS_SetDisabled | set an object as disabled for the visualizations |
IPS_SetHidden | set the visibility for an object |
IPS_SetIcon | set the icon of an object |
IPS_SetIdent | set the ident of an object |
IPS_SetInfo | set extended information of an object |
IPS_SetName | set the name of an object |
IPS_SetParent | set the parent of an object |
IPS_SetPosition | set the position of an object |
