IPS_GetModule
array IPS_GetModule (string $ModuleID)
| ModuleID | ID of the module |
The following information are available as key => value pairs:
| Aliases | array | Array of alternative names (string) for the module |
| ChildRequirements | array | Array of GUIDs (string), which are expected by child objects |
| ParentRequirements | array | Array of GUIDs (string), which are expected by parent objects |
| Implemented | array | Array of GUIDs (string) offered by the module |
| LibraryID | string | LibraryID in which the module is included |
| ModuleID | string | ID of the module |
| ModuleName | string | Name of module |
| ModuleType | integer | Type of module (0: Core, 1: I/O, 2: Splitter, 3: Device, 4: Configurator, 5: Discovery, 6: Visualization) |
| Prefix | string | Prefix of the module for calling the corresponding PHP functions (since Version 6.1) |
| Translation | array | Translations for ModuleName and Aliases (since Version 7.0) |
| URL | string | URL to the documentation website |
| Vendor | string | System/Manufacturer designation |
The command returns an array containing extensive information about the module with the ID ModuleID.
int_r(IPS_GetModule("{BAEA5454-4256-48AA-982B-538201A374D4}"));
/* returns e.g.:
Array
[ParentRequirements] => Array
[0] => {42DFD4E4-5831-4A27-91B9-6FF1B2960260}
[ChildRequirements] => Array
[Implemented] => Array
[0] => {8A4D3B17-F8D7-4905-877F-9E69CEC3D579}
[Vendor] => KNX
[Aliases] => Array
[0] => DPT 013.x
[Translation] => Array
[de] => Array
[KNX DPT 13] => KNX DPT 13
[DPT 013.x - 4-Byte Signed Value] => DPT 013.x - 4-Byte vorzeichenbehaftet Wert
[URL] => https://www.symcon.de/service/dokumentation/modulreferenz/knx/
[LibraryID] => {0945206A-47AA-4FDD-9093-99051E410E82}
[ModuleID] => {BAEA5454-4256-48AA-982B-538201A374D4}
[ModuleName] => KNX DPT 13
[ModuleType] => 3
