IPS_GetLibrary
 array IPS_GetLibrary (string $LibraryID)
LibraryID
ID of the library
The following information is available as key => value pairs:
Index  Type Description
Author string Name of author
Build integer Serial number for versioning
Date integer Unix timestamp
LibraryID string LibraryID
Name string Name of library
URL string Internet address of the library
Version integer HighByte: Major version, LowByte: Minor Version
The command returns an array containing extensive information about the library with ID LibraryID.
print_r(IPS_GetLibrary("{4414D465-0A32-49AC-929A-D948CBCDE06E}"));
/* returns e.g.:
Array
    [LibraryID] => {4414D465-0A32-49AC-929A-D948CBCDE06E}
    [Author] => Symcon GmbH
    [URL] => www.symcon.de
    [Version] => 512
    [Name] => SzenenSteuerung
    [Version] => 1.1
    [Build] => 0
    [Date] => 0
