IPS_DeleteMedia
bool IPS_DeleteMedia (int $MediaID, bool $DeleteFile)
| MediaID | ID of the media object to be deleted |
| DeleteFile | TRUE if the file should be deleted, FALSE if the file should be moved to the 'deleted' folder. |
The function removes the media object with ID MediaID from the media pool.
The media object can only be deleted if it has no children.
IPS_DeleteMedia($MediaID, true);
