IPS_GetLinkList
Require: IP-Symcon >= 2.1
 array IPS_GetLinkList ()
An array of all IDs of links in IP-Symcon presented as integer.
The command determines the IDs of all available links in IP-Symcon. The IDs are listed in an array. If no link exists, the array is empty.
$allLinks = IPS_GetLinkList();
print_r($allLinks);
/* returns e.g.:
Array
    [0] => 0
    [1] => 37659
    [2] => 18326
    etc. ...
