IPS_GetLinkIDByName
Require: Symcon >= 2.1
int IPS_GetLinkIDByName (string $LinkName, int $ParentID)
| LinkName | Name of the link |
| ParentID | Object whose direct child objects are searched |
ID of the found link, otherwise FALSE
The function tries to determine the ID of the link called LinkName whose parent has the ID ParentID. The ID of the first found link whose name matches LinkName is used. If such a link was found, its ID is returned, otherwise FALSE.
Caution: Names in IP-Symcon can be chosen freely, so they are not unique. For this reason, the function can return a wrong ID.
This function generates a warning if the name was not found. Use the @ operator if you want to suppress this message. The exact functionality of this operator is explained in the PHP manual.
$LinkID = @IPS_GetLinkIDByName("Linked rain sensing", $ParentID);
if ($LinkID === false)
echo "Link not found!";
else
echo "The link ID is: ". $LinkID;
