IPS_InstanceExists
 boolean IPS_InstanceExists (int $InstanceID)
ID of the Instance to be tested
If the InstanceID exists in the system, TRUE is returned, otherwise FALSE.
The command checks whether the instance exists with the ID InstanceID.
if (IPS_InstanceExists(45724))
    echo "Instance already exists!";
