IPS_GetInstanceList
 array IPS_GetInstanceList ()
An array of integer values ​​of all IDs of the instances in IP-Symcon
The command determines the IDs of all registered IPS instances in IP-Symcon. The IDs are listed in an array. If no instance exists, the array is empty.
$allInstances = IPS_GetInstanceList();
print_r($allInstances);
/* returns e.g.:
Array
    [0] => 37659
    [1] => 18326
    etc. ...
