IPS_GetInstance
array IPS_GetInstance (int $InstanceID)
| InstanceID |
InstanceID to be returned |
The following information is available as key => value pairs:
| Index |
Type |
Description |
| InstanceID |
integer |
InstanceID |
| ConnectionID |
integer |
ID of the connected instance |
| InstanceStatus |
integer |
Status code of the instance |
| InstanceSupportsSearching |
boolean |
Does the instance support the search mode |
| InstanceIsSearching |
boolean |
Instance is in search mode |
| InstanceVisualizationType |
integer |
Visualization type of the instance (0 (INSTANCE_VISUALIZATION_TYPE_NONE): None, 1 (INSTANCE_VISUALIZATION_TYPE_HTML): HTML, 2 (INSTANCE_VISUALIZATION_TYPE_HTML_FULLSCREEN): HTML fullscreen, 3 (INSTANCE_VISUALIZATION_TYPE_FORM): Form) |
| InstanceChanged |
integer |
Unix timestamp of the last time the configuration was applied |
| ModuleInfo |
array |
Module Information |
Status of Instance
| Code |
Constant |
Status |
| 101 |
IS_CREATING |
Instance will be created |
| 102 |
IS_ACTIVE |
Instance is active |
| 103 |
IS_DELETING |
Instance will be deleted |
| 104 |
IS_INACTIVE |
Instance is inactive |
| 105 |
IS_NOTCREATED |
Instance was not created |
| 106 |
IS_STANDBY |
Instance is in standby |
| >=200 |
IS_EBASE |
Instance is faulty |
Module Information
| Index |
Type |
Description |
| ModuleID |
string |
ModuleID of Instance |
| ModuleName |
string |
ModuleName of Instance |
| ModuleType |
integer |
ModuleType of Instance (0 (MODULETYPE_CORE): Core, 1 (MODULETYPE_IO): I/O, 2 (MODULETYPE_SPLITTER): Splitter, 3 (MODULETYPE_DEVICE): Device, 4 (MODULETYPE_CONFIGURATOR): Configurator, 5 (MODULETYPE_DISCOVERY): Discovery, 6 (MODULETYPE_VISUALIZATION): Visualization) |
The function returns an array containing information about the instance with the ID InstanceID. If the instance does not exist, a warning is generated.
print_r(IPS_GetInstance(19668));
/* returns e.g.:
Array
[InstanceID] => 19668
[ConnectionID] => 29416
[InstanceStatus] => 102
[InstanceSupportsSearching] =>
[InstanceIsSearching] =>
[InstanceVisualizationType] => 0
[InstanceChanged] => 1735686000
[ModuleInfo] => Array
[ModuleID] => {48FCFDC1-11A5-4309-BB0B-A0DB8042A969}
[ModuleName] => FS20
[ModuleType] => 3
