IPS_SetEventTriggerSubSequentExecution
 boolean IPS_SetEventTriggerSubsequentExecution (string $EventID, boolean $AllowSubsequentExecutions)
EventID
ID of the event to be changed
TRUE if permitted, otherwise FALSE
This command defines whether the event should be run again if it is triggered for the second time on a limit exceeded/ limit drop event. Otherwise, an event is executed only if the variable value was within the limit range and is again exceeded.
IPS_SetEventTriggerSubsequentExecution($EventID, true); //Allow
