IPS_SetEventLimit
boolean IPS_SetEventLimit (int $EventID, int $Number)
EventID | ID of the event to be changed |
Number | The number of executions before the event is deactivated. 0 = No Limit |
The limitation on Number causes that the event will only run as often as specified in the limitation. After running Number times, the event is deactivated. Setting Number = 0 removes the limitation.
IPS_SetEventLimit($EventID, 0); //No limitation
