IPS_SetEventCyclicTimeTo
Require: IP-Symcon >= 3.1
boolean IPS_SetEventCyclicTimeTo (int $EventID, int $Hour, int $Minute, int $Second)
EventID | ID of the cyclic event to be changed |
Hour | End hour (0..23) |
Minute | End minute (0..59) |
Second | End second (0..59) |
This command defines the end time for a cyclic event. The end time describes the last time of execution.
If the arguments for hour, minute, and second are 0, no end time is set and the last execution is at 23:59:59 at latest.
//No end time for the event
IPS_SetEventCyclicTimeTo($EventID, 0, 0, 0);
