IPS_SetEventConditionVariableDynamicRule
Require: Symcon >= 6.1
 boolean IPS_SetEventConditionVariableDynamicRule (int $EventID, int $ConditionID, int $RuleID, int $VariableID, int $Comparison, int $CompareVariableID)
EventID
ID of the event to be changed
ConditionID
ID of the condition that contains the rule
RuleID
Unique ID for this rule. IDs only need to be unique for this group.
VariableID
ID of the checked variable
Comparison
Value Description
0 ==
1 !=
2 >
3 >=
4 <
5 <=
CompareVariableID
ID of the variable that the value should be compared to
This function modifies the rule with the ID RuleID for the condition with the ID ConditionID of the event with the ID EventID. The rule compares the variable with the ID VariableID to the value of variable with the ID CompareVariableID according to the comparison operation Comparison. If no rule with the ID RuleID exists yet, it is created.
If VariableID is 0, the rule with the ID RuleID is deleted.
The variable types Boolean and String only support the first two comparison operations.
The value in Value must match the type of the variable with the ID VariableID.
// Create root condition for event with ID 12345
IPS_SetEventCondition(12345, 0, 0, 0);
// Add a rule with ID 2: Variable 23456 < Variable 34567
IPS_SetEventConditionVariableDynamicRule(12345, 0, 2, 23456, 4, 34567);
// Delete rule with ID 2
IPS_SetEventConditionVariableDynamicRule(12345, 0, 2, 0, 0, 0);
