IPS_IsConditionPassing
Require: IP-Symcon >= 6.1
 boolean IPS_IsConditionPassing (string $Condition)
Condition
A list of JSON encoded conditions in the format of SelectCondition
TRUE, if the condition is fulfilled, otherwise FALSE
This function checks if the JSON encoded condition Condition is fulfilled. It is typically used in conjunction with a module that uses the form field SelectCondition.
if (IPS_IsConditionPassing($Condition)) {
  // Only do something if the condition is fulfilled
