| GetValue | returns the value of an IP-Symcon variable, independent of its type |
| GetValueBoolean | returns the value of an IP-Symcon variable of the type Boolean |
| GetValueColor | returns the value of a color variable as integer in the format 0xRRGGBB |
| GetValueFloat | returns the value of an IP-Symcon variable of the type Float |
| GetValueFormatted | returns the value of an IP-Symcon variable and formats it according to its profile |
| GetValueFormattedEx | returns a value formatted based on the profile of a variable |
| GetValueInteger | returns the value of an IP-Symcon variable of the type Integer |
| GetValueString | returns the value of an IP-Symcon variable of the type String |
| HasAction | checks whether an action is defined |
| RequestAction | executes the variable action of an IP-Symcon variable |
| RequestActionColor | executes the action of a color variable with a color value in the format 0xRRGGBB |
| RequestActionEx | executes the action of an IP-Symcon variable with individual sender |
| SetValue | sets the value of an IP-Symcon variable independent of its type |
| SetValueBoolean | sets the value of an IP-Symcon variable of the type Boolean |
| SetValueColor | sets the value of a color variable from a color value in the format 0xRRGGBB |
| SetValueFloat | sets the value of an IP-Symcon variable of the type Float |
| SetValueInteger | sets the value of an IP-Symcon variable of the type Integer |
| SetValueString | sets the value of an IP-Symcon variable of the type String |
