Once a day
The "Timer cyclic second" module allows you to implement a timer that calls up the logic script every day at a specific time.
Properties
Name | Description |
Time | Time for triggering the timer. |
data points input
Active | Activation of the timer; if TRUE, the timer is activated and triggers the logic script at the set time every day. |
Hour | Data point of the module that controls the hour of triggering. If the input is not connected, the value of the "Time" property is used for triggering. |
Minute | Data point of the module that controls the minute of triggering. If the input is not connected, the value of the "Time" property is used for triggering. |
data point output
Triggering | Data point of the module that returns TRUE when the module has triggered. This occurs every second when the timer is active. The subsequent branch of the logic script is only executed if the timer has been triggered. |
No triggering | Data point of the module that returns TRUE if the module has not triggered. The subsequent branch of the logic script is only executed if the timer has not been triggered. |
