Property Editor
The Property Editor panel displays all available properties of a control element.
Each property consists of a name (left column) and an associated value (for technicians: key-value pair; right column).
When you create a new object on the drawing area, its properties are assigned default values from IP-Symcon. To customize properties to your needs:
- Click in the respective value fields and change the values.
- Save your changes from time to time (this may take a few seconds depending on your connection speed).
Overview
Outputs | Define outputs of a mapping module |
The Properties | Meaning of the properties |
Inputs | Define the inputs of a mapping module. |
Mappings | Editing the assignments of a mapping module |
